Picked up some pads and rotors for the rear of my truck. Hope to get to them soon. Need to do fronts and abs sensors as well.
It took all day literally to do. I started by sanding the clear coat off the inside of the bad. Then I used my air compressor to blow all the dust out. I then wiped the entire inside of the bed down with deglosser making sure to wipe down any areas that still had a shine to it. I used the Hercaliner kit: comes with 1 gallon of Hercaliner 1 scuff pad witch is useless and a brush and 2 rollers. It only took 2 coats and that's exactly how much 1 gallon can do. I'm gonna be adding a 3 and 4th coat to mine I want it a little thicker but I also do a lot of heavy duty hauling. I hope this helps and yes I will use this stuff on every truck I own even gonna use it on the daughters pickupHow do you like it? What type of prep did you do? How many cans and coats did it take?
Cool thanks for the info. I will need 2 kits as well probably cause I haul stuff everyday and want a good thick coat. Just debating wether to do it myself or take it to a line x shop.It took all day literally to do. I started by sanding the clear coat off the inside of the bad. Then I used my air compressor to blow all the dust out. I then wiped the entire inside of the bed down with deglosser making sure to wipe down any areas that still had a shine to it. I used the Hercaliner kit: comes with 1 gallon of Hercaliner 1 scuff pad witch is useless and a brush and 2 rollers. It only took 2 coats and that's exactly how much 1 gallon can do. I'm gonna be adding a 3 and 4th coat to mine I want it a little thicker but I also do a lot of heavy duty hauling. I hope this helps and yes I will use this stuff on every truck I own even gonna use it on the daughters pickup
Will do. Next time I have a chance to get her in the air that is. visually everything looks to be in excellent shape.It sounds weird but since I replaced my inner tie rod end/rod assembly I have not heard it. Might want to check yours
Ebay.GMC4x4, where'd you get your LEDs from?
It rained again today so I'll probably add some more mud to it.lol i generally will leave the mud on my truck for a week or so just as a trophy
