2000 LQ4 Exhaust (solved - Walker 55556 from 2001 - blueprint verified)
gatesl
Seattle, WA
Hi everyone. My stock 2000 LQ4 exhaust has a cracked flange on the passenger exhaust downpipe that I am trying to find the right part for. OD on the OE pipe is 2.5 until after the O2 sensor, then it's welded to a 3.0 OD pipe. I think this was a factory exhaust in 2000 due to the towing RPO code I ordered it with, and the HD model was introduced in 2001. I am trying to find a direct replacement part and having a hard time.
It appears the MagnaFlow BRExhaust Direct-Fit Exhaust Front Pipe Kit 107-0260 is close, but specified as 2.75 inch ID on the outlet which I think is a 2.87 OD. The Walker 55334 is 3" inlet and outlet. Does anyone know of a direct-fit that is 2.5 OD at the exhaust manifold flange end and 3.0 OD at the cat flange?
Would it be of any help if I suggested you examine LQ9 exhaust parts? If not, please ignore.
