2005 GMC 2500hd lly allison 4wd issue.
MrV
Oklahoma
So I have a 05 2500hd Duramax with the Allison trans and it has a 4wd issue. Sometimes the 4wd will work or at least I believe it is working, if I don't have the engine on and out the truck in neutral then hit 4h or 4l I can hear the solenoids/motors switching it and I believe the axle disconnect and the transfer case are working, I know the transfer case is working because just going 4h to 4l I can hear it and it seemed to be making noise from 2h to 4h but after driving it around or just switching between 4wd and 2wd a few times I get a service 4wd on the dash and either no lights on the 4x4 switch or the 2h light will be on but nothing happens if I hit the buttons. Curious if anyone knows where exactly is the best spot to start I have already replaced the switch and it does the same thing.
Supporting Member
Military
If you are in a "salt on the roads" area of Oklahoma, it can pay to remove the encoder/transfer case motor and inspect. Clean and lube where you can and also check for corrosion on the connector.
MrV
Oklahoma
We don't salt our roads here so that is a non issue, I just messed with the truck more and got it to work again consistently so I guess I will have to see if it holds up, I have never been a fan of the electronic 4x4 systems and all my trucks are manual case and manual hubs.
Supporting Member
Military
So, you are saying that your 2005 Duramax is a manual case and manual hubs? The 20 years of age, alone, can be a reason to pull the motor and inspect and inspect the connector.
I am with you on that, I prefer manual also! I am betting the encoder motor needs cleaned and lubed, or replaced like @ORVietVet said. That's where I would start.
MrV
Oklahoma
No it's the push button 4x4, I will pull the motor and connector next week probably. Is that just somewhere on the transfer case? I know this truck recently had the trans and transfer case replaced before I started working here on it truck only has 250k miles lol.
