Audio & Electronics
2005 Sierra all gauges suddenly dead
<blockquote data-quote="AuroraGirl" data-source="post: 25613" data-attributes="member: 9417"><p>the gauges if they arent fried or bad fuse would have a Sweep at key on engine off </p><p></p><p>If you have ANY gauges sweep then its fine but if none its most likely all failed somehow at once or more likely fuses/grounds</p></blockquote><p></p>
[QUOTE="AuroraGirl, post: 25613, member: 9417"] the gauges if they arent fried or bad fuse would have a Sweep at key on engine off If you have ANY gauges sweep then its fine but if none its most likely all failed somehow at once or more likely fuses/grounds [/QUOTE]
Y
Latest: YukonDenali03
23 minutes ago
dcairns
Audio & Electronics
