3 inch body lifts who's done them ?
sierra4.8
Who's done 3 inch body lifts on these trucks looking for info on install what needs to be extended how hard it was and pictures would be great
Kkirwan71
I plan on doing the 1.5" I'll let you know
badazzbulldog
medway,ma
if the truck you own is a duramax you already have a 2" from the factory they did that to clear the allison transmissions
BadChevyZ-71
Jacksonville,FL
I have. Did the 3" Performance Accessories body lift on my 01' Silverado 1500 Z-71. I still have the direction booklet and if wanted I can type some of it up.
If possible I'd save up a little extra and get a good suspension lift. If I was to do it all over again with my truck I would've waited, saved up a little bit more, gotten the 7"-9" Cognito Suspension lift with Bilstein or Fox shocks and no body lift. Live and learn. Now I'm making sure I do everything right with my Tahoe Z-71, only difference is I don't plan on making it sit as high as my Silverado.
Clarke67
just built my own 3" body lift on the sub/avy platforum. have done them before. order the performance acc blocks from 4 wheel parts. order the bolts off amazon ect. (170mm iirc).
everyone talks shit on them, but just like anything, if done by a hack in a trailer park.. it will be a hack. when used they offer many benefits, such as clearing larger tires with keeping the center of mass lower for better handling, easier access for maintence. opens up the possibility to do mods everyone else cant! ECT this is my 2003 zf6 built engine pull truck, just parking lot pose'n
