CB mounting locations
JorgeS
Anderson, IN
I routed my co-axxial cable through the same grommet that brings the parking cable into the passenger compartment. This was a little tricky and I used a length of RG-174 cable with SMA connectors at the radio end, and an qualilty antenna base at the other end that accepted an antenna with a PL259 base. This was for my amateur radio dual band radio with 50W output; RG174 cable is very thin, and the SMA connectors are also quite small.
I took an old aluminum tent pole, made two axial cuts at one end one (90 degrees to each other) that were about 1.5" long. I then bent these in to make a point. I used this tent pole as a sort of needle, and pushed it through the grommet opening, halfway into the passenger compartment. I then pushed the RG174 cable into the "needle" (the SMA connectors fit into the tent pole). I pulled the "needle" into the passenger compartment from inside, and it brought the cable with it.
SMA to PL259 and SMA to SO-239 adapters are easy to find. This allowed me to make the connection to the radio.
Since I have a Yukon, I had to fabricate the antenna bracket (they're available for Silverado/Tahoe, but not for Sierra/Yukon!!!). The second photo shows the thinness of RG-174 cable.
[EDIT on 3/3] - Forgot to comment on wiring: I used the same method (Tent-peg "needle") to bring #12AWG wires from the power block under the hood to the radio. I can run up to 50W on the 144 MHz band, meaning 100W+ input into the radio. For a (legal) CB, your maximum current is around 2A, so should be able to have good results with #16AWG wires, which would be easier to run. In the past, when I was running a CB, I tapped into one of the circuits under the dash with good results.
Good luck!!
