Well in this thread i will show you step by step on how to change out the regular bulbs in a stock nbs cluster. To make it easier on people ill do this step by step so if your doing this while trying to look you don't lose your place.
To start this mod you will need these items
1. Soldering iron ( adjustable would be best ) [6.99-39.99]
2. Solder ( acid free so it won't eat the circuit board ) [2.99]
3. Solder sucker ( Optional ) [5.99
4. 9 3 mm Flat top LEDs ( Will show reason for flat tops later on) [7.49/100]
5. 9 680 ohm resistors ( Mine i believe are 1/2 watt ) [1.49/6]
6. Flat head screwdriver [2.99]
7. 7mm socket and driver [9.99]
8. A clean fork [0.99]
9. Stepper motors ( If you have gauges that don't work right) [15.95]
Prices w/o taxes
With all part [56.36]
All but motors[40.41]
With all but hand tools [26.44]
1,2,4,5,6,7, and 8 are needed in the process of replaceing the bulbs to leds
3 and 9 are mainly for the stepper motors but 3 helps alot to get a clean solder on the leds with out build up.
Also with the leds I recommend getting 100 since there so cheap and you can do the rest as i post the how to's for the doors and all the controls
Prices w/o taxes
