Fog Light Install - Nonfog light truck (AFTERMARKET)
monsterade
I want to wire fog lights on my 02 silverado, non-equipped with factory wiring, and without flashing my BCM.
In other words, I want to buy an aftermarket wiring kit (880 i'm guessing), buy the OEM fog light housing, buy bulbs, and wire it manually to a fuse and then ignition switch, then to a toggle switch I am going to mount in the spot below the cargo light switch where my OEM fog light switch would've been.
Has anyone done this? Can you provide pics/information/wiring? Thanks.
Kkirwan71
I have mine wired to my low beams with a relay when I did the z71 tahoe valence on my truck
Sent from my SAMSUNG-SM-G891A using Tapatalk
Kkirwan71
Can you post pictures? Of what it looks like and the wiring?
My bad I've forgotten about this you just get pigtails for the lights you want. Most have a black wire and a white wire. The black is your ground. Run a wire from the power wire on the passenger side over to the wire on the driver side then run said wire to the relay and wire the relay up accordingly
