Fuel Composition Pid
<blockquote data-quote="stutaeng" data-source="post: 27674" data-attributes="member: 6175"><p>Ok, that's correct. I guess I was confusing the alcohol content senser on the GMT900?</p><p></p><p>Do you ever run that flex fuel in your truck? If not, I'm pretty sure you can simply get rid of it on the ECU tune. Then it will run like a regular non-flex fuel engine.</p></blockquote><p></p>
[QUOTE="stutaeng, post: 27674, member: 6175"] Ok, that's correct. I guess I was confusing the alcohol content senser on the GMT900? Do you ever run that flex fuel in your truck? If not, I'm pretty sure you can simply get rid of it on the ECU tune. Then it will run like a regular non-flex fuel engine. [/QUOTE]
Y
Latest: YukonDenali03
Today at 6:41 PM
jfmorris
