List of parts needed…
-factory fog light housings from Amazon
-880 fog light harness from Amazon
iJDMTOY Wiring Harness
https://a.co/d/3A8VCWh
Next remove your grill, parking lights and bumper. Removing the bumper makes it easier to run the harness and install the fog light housings.
Connect the main power for your relay harness to the main power from the battery and use the brown wire on the parking lamp harness to trigger the relay. The fog lights turn on every time the park lamps or head lights are on, an added bonus is that they say on with the high beams. Since my truck is a 1999 I have a diode between my white and gray wires on the BCM to disable my automatic headlights.
