Identifying 06 seat fabric ( buckets ) two tone
Aaron81
Michigan
Here to see if anyone can identify this color or trim rpo code just from generally seeing this color pattern. The buckets are from an 06’ the seem to have a tweed type of feel and look not really from the era but maybe it’ was a normal fabric in some trim levels have a matching full leather gray rear seat I want to swap the front covers out to match the rear in full vinyl .
These may have been a standard cab w/t seat . Not sure I come from the 88/98 Obs trucks . So new to the nbs interior stuff
Basically trying to source a cover set online or eBay that matches the head rest vinyl / leather it looks like pewter maybe ?
Please post a pic of the RPO codes sticker from the glove box cover and also a pic of the door or door jam sticker that has the VIN on it. The interior codes should be there.
I gotta say that I have never seen the "tweed" look seats in anything other than 2007/NNBS trucks or newer BUT, I could be wrong.
If you read it, disregard what I had posted, before I just deleted it, the seat belt roll out info. I was wrong. Both my 2005 Tahoe and my 2004 Silverado, belts roll out of the seat.
NEVERMIND!
Aaron81
Michigan
I would but these were bought 2nd hand hence why i asked here maybe someone just could identify by visuals just knowing from having a set of the same seats . I’m working on getting the rpo code for the person I bought these from
Ok, If you post the VIN, I will go to another source and type it in and get the build sheets. You can also do that yourself at : https://chevroletforum.com/forum/register.php?step=addmember.
At the top, go to TOOLS and the drop down will have the VIN Lookup Option and when you do type in the VIN, make sure you capitalize the letters.
I think I just understood what you meant. You bought these seats loose/second hand and do not even have the VIN, correct?
Sorry about the misunderstanding.
It may be a PITA but sometimes the seat fabric/covers have an I.D. tag inside a flap. May have to take partially apart for viewing that.
Or hopefully, someone here is not as dense as I am this morning and can identify these.
Since you are trying to match the rear seat, do you have pics of that or any info for the truck it came out of.
Sorry if I seem dense but as I reread your post, the lack of punctuation in some places makes it difficult to follow the flow of what you are saying/asking.
Aaron81
Michigan
The goal is to obtain close if not exact matching color of the rear bench seat and get the fronts the same one solid vinyl gray or pewter or whatever it is .. with a pre fab seat upholstery cover ( quality ) online for the fronts . Also need core bottom bottoms maybe ! I’ll have to look at the bottom wire netting to see if it’s bad .
The front buckets came out of an 06’ that much I do know
The rear bench I can find out the Vin and rpo later this week .
Here is the rear bench ( color ) only pic i have prior to having yet pulling it from the donor truck . I am picking it up this week
Work Truck seats, same that came in my 2000. Here's the full gray vinyl covers I used to swap mine:
thanks it’s my understanding that 99-02 cores are specific and 03-06 are also different.. I was told by a few sources that make the cores aftermarket .. So does that make the aftermarket seat cover pattern The same from 99-06? Or would they also be 99-02 and 03-06
And btw do they really fit that loose ? I see the photos you shared looks loose fitted
TooleyOnDeck
Crestview, FL
The first pic was the day of install so they were wrinkled bad from being vacuum packed. Actually, the driver's seat bottom was a little loose and I had to hog ring it to tighten it, but both seat backs and the passenger bottom were tight. The wrinkles have mostly flattened now that it's been about a month and the weather is warming up. Those weren't the exact same ones I ordered though, mine were around $135 so I'll have to go find them in my purchase history, but they are the same color, charcoal gray.
I am not sure if the seats cores are different from 99-02 & 03+ but I own both and I can't see any difference aside from one being power seats with an arm rest and my single cab seats being manual with no armrest. They bolt up the same and are interchangeable.
I can tell you that Pewter seats will be RPO code 922 and a light tan color. My 03 Yukon has those.
Aaron81
Michigan
i got the rpo code sticker from the truck that had the rear bench.
Can you help me identify which code would be the interior color or the seat color IMG_0467.jpeg
Aaron81
Michigan
Also, it appears that rear seat came from a Silverado SS or Escalade EXT.
It was a red 2006 already gutted nothing left inside..Not sure about ss .. they had there way with it . I only needed the rear seat 100$ bargain
But back to the matching of the sem paint either with the ( name ) dk charcoal or the color code 692 . What’s the closest match in paint that way I can paint my dash and trim to match the seat tone . If anyone has done so with that code
TooleyOnDeck
Crestview, FL
They probably have several names for the same color, but the only way to know is to start throwing some paint on there and see if it matches. I personally didn't bother matching it and did my own 2 tone black/gray and repainted the entire interior.
