Fixinit
I've got a LS gen III/IV pressure plate on a 2001 5.3 engine I'm putting into a 92 2500. I'm using an external slave cylinder and so need to use a 80's throwout bearing. I put a Advance Adapters bell for a NV4500 in, it's set up for external. So now I need to bolt a 80s style pressure plate that will fit that old style throwout bearing onto that later model flywheel. Well, turns out the six bolts line up just fine. But I bought some bolts for the flywheel from Summit that are supposed to fit 97-19 flywheel, and they are 10 mm and thread in nice but they dont have shoulders on them, they're all thread. If they had the top 1/4" no thread, just a straight 10 mm, the bolts would do the aligning. That later model flywheel came with alignment pins (2) so I guess thats why they didn't come with shoulders, the pins kept thing lined up. But that old style pressure plate has no holes for pins and there isnt a flat place to put them in if I wanted to. So my question is has anybody ever done this before and if so how? I'm thinking if I just had two or three 10 mm bolts with Unthreaded shoulders the PP would be all centered up. Thanks, hope this wasn't too complicated. BTW that old flywheel that came with the 92 worked fine with a 03 NV4500. But it was on a 92 5.7. I don't know what PP it had but it looks different. Three of the six bolts are smaller than the 10mm holes. Looks like three are 3/8", no idea how that was supposed towork
