Mating lq4 to 4l80e
Stevee5039
Salem oregon
I can't get the motor to draw the last 1/8 inch towards the tranny on one side. Is there a trick? I think the dowel is corroded or just slightly stuck
Sometimes those dowel pins seize and rust. I always apply a good amount of lubricant on the dowel pins before trying to mate the two.
Be sure to check converter spacing against the flywheel should be 1/8 to 3/16.
Actually before trying to mate the two, check that torque converter is fully engaged. I place a straightedge across the bell housing and measure to the converter pads. I believe it should measure 1"? If that's good then you can proceed to mate the transmission to the engine.
