No interior power but Truck runs Fine
Brantford ON Canada
Hello all, I have a 2007 GMC sierra Classic 1500 SLE 4x4 5.3l Ext cab.
I love this truck as it was my father's and I've been able to manage the very little maintenance very easily. However I'm having an electrical grimlin.
What doesn't work.
Power mirrors, all gauges, radio, subwoofer, AC, power locks, remote for locks and alarm, cluster info like fuel and trip. And OBD2 scanners say 'Lost Communication" and won't read
The 4x4 service message pops up. And the light comes and goes, same with the lock light and abs and emergency brake light and battery light. No engine light.
What works, the blower for the HVAC works, the speedometer and rpms work. The truck turns on and runs perfect even after 1.5 hour drives. The lights on the outside work and the inside lights work but sometimes won't turn off.
Things me and my mechanic checked
All grounds, battery, alternator, new Bcm, and new cluster, checked by slowly unplugging all mini computers in the system 1 by 1(such as window switch, radio, 4x4 button, etc.)
Originally it started with just the gauges powering off and on here and their then the radio then the switches and lock and eventually all of its now not working.
Any help at all would be absolutely awesome
Does the truck have any rust?
It's weird that certain cluster guages work, and others don't.
I would just pull wiring diagrams and pick a system and do your basic electrical troubleshooting that system. Check for power and ground. Actually, prior to that, you should do a full scan on the body modules. I bet they are off-line if they don't have any power...
Check here for free diagrams: https://lemon-manuals.la/Chevrolet/2007/Silverado Classic 1500 4WD V8-5.3L/Repair and Diagnosis/
AllData is another source for wiring diagrams. You can pay $20 for a monthly membership and download all the diagrams in PDF format. Very worth the price.
Welcome to the forum!
It sounds like something is bringing down the Class 2 Serial Data. Tach and Speedo have their own signal feeds to the cluster. All the rest of the gauges get their data from the serial data. I would expect there's a rub through in the harness with a short to ground. Class 2 Data is 0-7.5V. Here's a diagram to get you started. There's a couple more that include seat modules, suspension, rear HVAC.
EDITED pic for correct year and trim level. There's a couple extra modules.
Splice pack SP205 is located right behind the interior fuse panel. It can be white or black, and looks like a blank plug in the end of a harness. SP205 is also the first splice pack that comes off of the PCM.
Do you have a pocket oscilloscope or at least a code scanner?
Brantford ON Canada
I have a scanner but the obd2 also states lost communication
So if you go to that splice pack behind the interior fuse panel, it will have 12 pins and they'll be labeled A-M. If you connect pin B to pin D with a piece of wire, try reading the codes again. If the splice pack is bad, another module is bad, or the break is somewhere down stream of that, you should be able to read codes.
If that doesn't work and your scanner gets its power from the port, there's two more plugs. The one at the PCM and the one where the main harness connects to the interior harness. Check both of those for corrosion or other issues. Check for rodent damage while you're poking around the engine compartment and under the dash.
Brantford ON Canada
Hello, just got my truck back from my mechanic who gave up looking lol. I have an oscilloscope coming in today sometime and if possible I'd like to test every module line through the splice packs. Due to the obd2 saying lost communication on the scanner will I have to do anything extra then check every pin in the splice pack or should I be fine to try and hunt down the problem
Brantford ON Canada
Also I have not used an oscillioscope ever in my life lol. What would I be looking for and are their any specific settings I should have it set to
Just hoop it up to the circuit. Turn on and the the settings and you should see the waveform change as the signal changes. There should be some adjustments on the scope to capture the waveform, like millivolts and the time interval on the horizontal scale.
What scope did you buy BTW? I've got an older OTC scope i bought a few years ago. It's like from the 90s. I replaced the battery pack, but it works just fine. Has come in handy. Scopes are basically like a graphing calculator and a voltmeter.
Brantford ON Canada
This guy came in today, looks well and is pretty simple lol, I'll probably mess around with it tomorrow, so before I use it to read the pins do I have to bridge 2 pins with a wire or is that just for the obd2
