P0332/ P1516
<blockquote data-quote="ORVietVet" data-source="post: 22025" data-attributes="member: 9438"><p>Welcome to the forum from Oregon, [USER=12063]@03_sierra[/USER]. </p><p></p><p>What [USER=11207]@bigdogYJ[/USER] said about the ground(s). Especially if the codes came at the same time. I completely agree with using Genuine GM parts or AC Delco. Make sure about the throttle body/bore clean while you are in there. The actuator and position sensors harness connectors are always suspect and need inspect as well. The other place to look is the throttle/accelerator pedal position sensor should be looked at as well. This is a hidden sensor and other forgotten about. I had a problem with mine on my 2005 Tahoe Z71.</p></blockquote><p></p>
[QUOTE="ORVietVet, post: 22025, member: 9438"] Welcome to the forum from Oregon, [USER=12063]@03_sierra[/USER]. What [USER=11207]@bigdogYJ[/USER] said about the ground(s). Especially if the codes came at the same time. I completely agree with using Genuine GM parts or AC Delco. Make sure about the throttle body/bore clean while you are in there. The actuator and position sensors harness connectors are always suspect and need inspect as well. The other place to look is the throttle/accelerator pedal position sensor should be looked at as well. This is a hidden sensor and other forgotten about. I had a problem with mine on my 2005 Tahoe Z71. [/QUOTE]
Y
Latest: YukonDenali03
Today at 6:41 PM
Daveb
Hammer54
P0332/ P1516
