Rear Window Washer Pump Question (Tahoe / Burb)
FW_Z71Burb
Fort Worth, TX
Yo -
the Burb's rear window washer fluid line has a crack near the rear bumper which leaks fluid.
question about the operation of the washer pump:
- can I fill the reservoir with fluid and only pump the front windows? meaning, does the pump pressurize the front and rear line or only the ones you direct it to wash?
like if I only use the front washer for the front windshield, does it pump to the front only or does it also pump the rear?
i've tried to fix it but didn't have the right size hose to splice it. trying alternate methods
Yes, the windshield washer reservoir has 2 independent pumps. I had an annoying leak on my 06 from the reservoir last year, especially in the summer heat. I replaced the grommet/seal on the pumps and it was still leaking. I finally ordered a new reservoir that came equipped with the pumps.
As I mentioned previously, my rear line leaks at the connection near the battery, so I never really use the rear. But the front works just fine.
FW_Z71Burb
Fort Worth, TX
I believe so. You can repair the crack with fuel line. Cut at the crack, slide the fuel line over and use that as an outside repair. Not the greatest fix, but easy.
that's what i planned to do, I had some extra fuel line from my old 93 Bronco Fuel delivery woes but it had the wrong Inner Diameter and wouldn't work, jsut need to source some new fuel line
EDIT: I think the washer line is 3/16" diameter? would you happen to know?
FW_Z71Burb
Fort Worth, TX
awesome thanks Stu... mainly trying to get rid of the annoying yellow light on the dash on ignition but also have windshield washer fluid for the front windshield lol
I think you're right. But 1/4" should work.
