Transfer case not shifting into 4x4
<blockquote data-quote="stutaeng" data-source="post: 27817" data-attributes="member: 6175"><p>Check out post #8 & #11 here: performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/service-4wd-message-560255/</p><p></p><p>You can take it apart and measure the resistance of that wheel. Mine was very erratic as I was spinning, jumping all over the place. Alldata has instructions on how to clock or time the wheel, but I believe you just align the wheel dot with the case mark.</p><p></p><p>I hope this helps.</p></blockquote><p></p>
[QUOTE="stutaeng, post: 27817, member: 6175"] Check out post #8 & #11 here: performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/service-4wd-message-560255/ You can take it apart and measure the resistance of that wheel. Mine was very erratic as I was spinning, jumping all over the place. Alldata has instructions on how to clock or time the wheel, but I believe you just align the wheel dot with the case mark. I hope this helps. [/QUOTE]
Y
Latest: YukonDenali03
Today at 6:41 PM
