Undercarriage Input
<blockquote data-quote="AuroraGirl" data-source="post: 28993" data-attributes="member: 9417"><p>gm put steel wheels under the truck for the spare to prevent cosmetic damage to the wheel and also because alloy/aluminum tend to get corroded bead seats esp with road salts. so they dont hold air.</p><p></p><p>you can use whatever you want, just consider a shield or taking extra steps to preserve the wheels appearance and remeber to rotate it in the pattern</p></blockquote><p></p>
[QUOTE="AuroraGirl, post: 28993, member: 9417"] gm put steel wheels under the truck for the spare to prevent cosmetic damage to the wheel and also because alloy/aluminum tend to get corroded bead seats esp with road salts. so they dont hold air. you can use whatever you want, just consider a shield or taking extra steps to preserve the wheels appearance and remeber to rotate it in the pattern [/QUOTE]
Y
Latest: YukonDenali03
13 minutes ago
YukonDenali03
Undercarriage Input
