Stall converter
Gavin
Windsor California
I have a 2001 gmc sierra 1500 4x4 with a BTR stage 2 V2 truck cam with 33” tires. It’s pretty sluggish on the bottom end and can’t even break the tires lose. I’m looking into getting a stall converter in the 2800-3000 range, I tow with it and daily drive it so I don’t want anything too crazy. I’m just wondering what size? From the research I’ve done I think a 2800-3000 258 mm would be the best for my setup. Let me know what you guys think and if anyone is running a similar setup
I have a 2001 gmc sierra 1500 4x4 with a BTR stage 2 V2 truck cam with 33” tires. It’s pretty sluggish on the bottom end and can’t even break the tires loose.
I’m looking into getting a stall converter in the 2800-3000RpM range, I tow with it and daily drive it so I don’t want anything too crazy.
The cam did not make breaking the tires loose any easier, did it? (Taller tires didn't help either.)
A higher stall-RpM will strain the transmission, even when you're not towing, even with an ATF cooler upgrade, moreso when you're towing.
You want more power UNDER 3000RpM. A higher stall-RpM doesn't add more power under 3000RpM.
I think without gears it will still feel sluggish.
Fixed it. Your Sierra needs a better tow rating.
Your Sierra needs 4.10, possibly even 4.30. Axle gears will not make your engine any stronger, but it will make your VEHICLE stronger.
