YukonDenali03
seattle
I'm a retired Software Design Engineer that has also owned a 2003 Yukon Denali since new. After rebuilding the engine last year because of a low oil pressure problem caused by a Cam bearing failure, playing around with the truck has become my new hobby.
Eventually I became interested in what you can do via the OBD port. So, I decided to write an app the explore that as a little programing project to keep myself busy.
I have managed to create a little app that I think other might find useful.
1. It can scan and clear DTC's. I know this isn't new, but it can scan ALL the modules on the class 2 bus in under 5 seconds. My Launch tablet take close to 2 minutes.
2. It can issue commands to various modules on the Class 2 bus.
a. It can sweep the cluster gauges to see if any of the stepper motors are bad.
b. It can cause the front and rear HVAC modules to rerun the calibration procedures. That might help with actuator problems.
c. It can controls the windows and locks, because why not.
d. It does other stuff too.
Based on feedback, lots of other can probably be added. Give it a try and let me know.
The application runs on Windows and use ELM327 devices to connect to the OBD port.
I have used and OBDLINK SX connected USB and an OBDLINK MX+ over Bluetooth. I make no promises about cheap Chinese knockoffs.
The UI is pretty simple and hopefully self-explanatory.
It should go without saying that this is a Windows executable file. I have signed the file, but Windows is going to give you a scary warning about an unknown file. I would fully encourage to you to scan it with your malware detector of choice.
gmt800app
Send feedback to [email protected]
Sweet. Is there any way to snoop the oil pressure sensor value and display that?
gmt800app
YukonDenali03
seattle
The pid for oil pressure is available. The only way I know to query it is by building a what I would call a dynamic query and then request that the data from the dynamic query. It is not as simple as a regular OBD pid query.
One of my ideas is to add the ability to query live
Any advantages of this set up over a scanner that has Live Data and Bi-Directional capabilities?
IF you have a full feature bi-di scan tool this probably isn't going to get you anything. I do like that I can scan all the modules in less than 5 seconds though.
YukonDenali03
seattle
A newer Snap On or Autel or Top Don scanner is that fast as well. But thoroughness is more important to me than the speed. Nice job designing this.
Then they are definitely better than my Launch device. Get what you pay for I guess.
so it can display all pids? Can it do all Feature functions a tech 2 could command? Like a cylinder balance test? Fuel pump on? Etc
Reading pids is something I am working on now. I would assume I can do most of the thing's tech 2 can do. I just need to capture the message traffic across the class 2 bus and reproduce it. One limiting factor is the ELM327 is a command-response device. It can't really handle unsolicited traffic well. So, if the operation can be done via commands and responses, I should be able to do it.
