Crew cab rear door lighting
Is there electric windows there? I would assume so. If so, then can run some wiring along the same route as the wires that are there. Maybe I am over thinking it. Are you talking about lights at the bottom furthest back corner of the inner door panel?
Goat
East Texas / Northwest Louisiana
Is there electric windows there? I would assume so. If so, then can run some wiring along the same route as the wires that are there. Maybe I am over thinking it. Are you talking about lights at the bottom furthest back corner of the inner door panel.
yep! Them are the ones. The courtesy lights.
So, right now you just have reflectors and want to add lighting that comes on when door is open, correct? Bound to be lights like that available that you can wire in. I think my 05 Tahoe has those lights?
