Gauges/Dash Gremlin....HELP!!
MikeRi24
First time posting here but I own 3 2500HDs for my Landscaping business. Anyway, I have a strange problem on my '06 2500HD....for a while, the dash lights would dim all the way but after playing with the dimmer switch, they would come back.
Now, I have no dash lights at all and none of the gauges work. However, if I raise my snow plow or change the angle, everything works for a while it then it all cuts out again. It seems like it only works when there's a load on the system or something.
If the truck sits for more than a few days without being driven, the battery also dies. Any suggestions?? Thanks!
Jrgunn5150
I would say you have a short somewhere, I would look at the plow controller, and where it's tapped for power.
theres some resistors in the cluster itself the become broken at the soldering contacts and you need to resolder the contacts to fix it i had the same problem theres 7 bunched together in the upper left side in the middle
