OEM upgrades
A lit up Bow Tie?
Wheel center caps with black Bow Ties in the center?
Get the mirror caps painted black?
DateNight
Tx
does yours door mirrors have puddle lights under them? That would be a good up grade.
You can add foot well lighting also.
If you have a z71 roof rack like @ORVietVet has you can install lights on the rear flush in the rack.
If you have a factory sub in the rear cargo area you can pull the signal from the speaker wire at the sub and run them into a Line out Converter and install the amp where the factory sub is located then run what ever sub and box you like.
dreid13
Pennsylvania
I do have puddle lights that I swapped to LED already. Sweet idea about the z71 rack lights, im definitely gonna do that. Footwell lighting as well definitely seems like a good upgrade. Thanks for all the ideas!!
DateNight
Tx
maybe a black Bow tie, or something other than the factory color.
Walmart sells cheap rolls of sticker vinyl in tons of different colors. Endless possibilities. Lay it over and cut it out with an exacto knife
Looks like this
Check this link out for how he did it:
dreid13
Pennsylvania
Looks like this
Thanks!
bigdogYJ
Kommifornia
If you want Bluetooth audio for phone calls over the factory stereo you can swap in a OnStar box from a 2009ish corvette or I’ve heard the trailblazer also offered Bluetooth phone calls. You just have to ensure the year you get it from has Bluetooth (there’s a logo on the label of the box) and it’s still on the class 2 data bus. If so the box is plug and play and factory steering wheel buttons allow you to answer phone calls and initiate hands free calling on your phone.
At least it puts some of the obsolete OnStar hardware back to use.
Note this does not allow music to play on your stereo. There’s a different solution for that but it’s kinda aftermarket-ish. But the phone calls one is more oem like. If you want more details let me know.
bigdogYJ
Kommifornia
For reference I found part # 20794960 from a 2010 corvette c6.
The top box is the c6 unit. You can see the Bluetooth logo on the right. I remember modifying the mounting bracket slightly since the new unit was a bit thinner. I don’t recall the years but trailblazers and maybe Cadillac srx or something like that had the option as well.
dreid13
Pennsylvania
Just out of curiosity, where is thus box located on our trucks? And was it plug and play?
