Last week I got a Service Engine light with a P1441 code on my 2001 Suburban 5.3... "EVAP system flow during non purge event". I replaced the purge valve about a year ago due to another code. I pulled the line from the valve, stuck a hose on it and tried to blow through it. I couldn't really get any air through, but I thought it might be an intermittent failure of a cheap aftermarket purge valve, so I replaced it again. The code came right back. I had also ordered a vent valve a while back and never put it on, so I went ahead and did that. It also has a fairly new gas cap. The code came back again.
What are my options at this point? A hole/split in a hose? A wiring issue? A fuse? Fuel tank pressure sensor? Before I spend a lot of time trying to locate a leak, are there any other easy things to check?
It seems to run fine, but the exhaust maybe smells a little bit rich.
