3 inch lift
i know someone on here has to have done a 3 inch leveling kit, can you post pictures of it, possiblly before and after?
962000chevy
Give me about 2 weeks and I can show you the front pics mom is gonna watch my baby so I can install my leveling keys and bilstiens.
awesome, id love to see the before and after to see if thats what i want to do, the kit im looking at is keys in the front and 2 inch blocks in the rear
Erki
Alberta, Canada
Wish I would have taken measurements to actually know how much the front came up, but here is a before and after.
[/URL]
Erki
Alberta, Canada
That picture was just the front. But I'm not sure if the 1500hd sat higher stock or not. Those are also only 265/75/16 tires.
im curious if 3 in the front and 2 in the back will make it slightly higher in the back, mine is pretty level stock
Erki
Alberta, Canada
I'm guessing 2" in back will put it about an inch higher than the front. But that's just a guess. It's it 2" lift in the back or a 2" block. You may already have a1" block from the factory that you will replace. Therefore if your getting a 2" block it will only raise the back 1"
it supposed to be a 2 inch block but everyone so far is saying that your not going to get the whole 3 inches in the front
962000chevy
3 inches up front may be possible but your angles would be terrible. I'll crank down my stock keys and get some measurements before I install my RC keys and then crank to see how much I'm comfortable with.
962000chevy
I'm not sure. I haven't seen any easy fixes simply because even if you don't break CVs every single wearable part under your front end wears faster.
962000chevy
When getting a 6 inch lift kit get one that is a full 6 inch differential drop so that way if you wanna go taller you can crank the bars an inch or two.
