Good brake and rotor kits
Halfton_z71
Hey guys, what's your go to brake and rotor kits? I'm looking to redo mine soon and don't want to use garbage. I also dont want to break the bank but I know you have to spend a little more for quality. Truck is a 99 1500 silverado Z71 LS. Thanks!
jfmorris
Huntsville, Alabama
I bought POWER STOP brake pads, shoes and rotors from RockAuto.com for my 2006 Silverado a few years ago, after seeing folks recommend them over on another Chevrolet forum I am on, and have been VERY pleased with the performance.
Unless I just need something in a hurry for an unexpected repair, I've gone to using RockAuto for all of my parts needs, rather than the local places like AutoZone. Much cheaper, and for expected maintenance, I can wait a few days for it to get here to save that money.
I did the first (after originals), front pads on my 1999 Silverado at around 120k using dealership pads.
Second set of AAP's highest line around 225k. Those dusted badly but otherwise seemed fine.
I replaced the rear pads around 230k, I think with something from Oreilleys.
Did the 2019 front brake upgrade around 270k. Very nice stopping power improvement :)
283k currently.
Edit: You have to run larger rims for the 2019 front brake upgrade, so that may be a deal breaker for you.
I replaced the rear rotors/pad on my 06 Suburban 2500 with some Powerstops a few months ago and I have been pretty happy with them.
Rotors- Centric
Pads- Akebono (if willing to spend more) or TRW
Calipers- Purchase these locally with a lifetime warranty.
If you intend to keep the vehicle, Autozone pads aren't a bad idea for the warranty. They warranty worn pads. I have done a few brake jobs where all I had to purchase was rotors. The other new items were warrantied.
mike8449
North Carolina
I put Powerstop vented & slotted rotors and ceramic pads front and back on my 2002 Chevy 2500HD two years ago. I've had this truck for nine years and it has never stopped this well. And this is still with the original calipers. 240K miles. Powerstop is pricey, but I'm very happy with the performance.
I have a pair i brought last year still in the box, maybe i should list them as "rare" and "collectable" or "vintage" for 3x what i paid;)
Especially at FB. If you use them......your warranty is s*h*i*t!!
Do you have happy brake pedal feel, and do you have any concerns about dust or do you not care/have wheels it doesnt show up?
I have ceramic front and metallic rear , and did so because of rear rotor corrosion and face flash rusting concerns because of the less amount of pad pressure in the rear brakes with the same size pad mostly (so less pressure)
I have very good pedal and not much dust seems to come off them
2019+ Silverado brake upgrade? View attachment 5533
283k currently.
I have 2019 Ram 1500 18" wheels on my Yukon... anyone know whether the 2019+ calipers will clear these wheels? (why? they were priced well with Falkens in good shape, and I like how they look on the truck, and they are different than other GMT800s out there).
My pads are still "OK", but I will be doing an upgrade before they were out. If I can determine that the four-piston calipers will clear the Ram wheels, I may go to them, if I do't feel confident of the fit, I will upgrade to the GMT900 calipers (already have the larger rotors).
Thanks!
Thanks!
There's a thread on here that documents which wheels fit, you may want to check it out: https://www.performancetrucks.net/f...on-calipers-fitment-wheels-list-558552/page7/
If you know the backspacing on your Ram wheels, you may want to compare that to what those guys say you need and make a guess? Worst thing that can happen is you need some spacers or do some caliper grinding. I'm running some 2014-2017 18" Tahoe wheels on my truck right now (post #86), just had to grind the the inner side of the calipers.
I think I'll wimp out and just use the GMT900 brakes. Current brakes are not bad, upgrading to the GMT900 will be an improvement, which should be sufficient.
It looks like the Ram wheels have less offset than the GM wheels, which is why the tires are basically slush with the body, which I really like how they look. While this will diverge a little from the OE front-end geometry, it is small enough to now worry about it, and I see many trucks with much greater change, with tires a couple of inches outside the body, that I should be fine.
