Dash Hole?
If you buy a filler delete like what I linked, you can drill holes in it for rocker switches for aux lighting or what not?
Agreed. Either a plate with switches or something stored in the hole. Not just sitting there empty.
Mine didn’t come with driving lights so that is where I put the switch. Made my own panel to cover that useless hole. These days you can order a 3D printed panel. They weren’t readily available back when I did mine.
Briggs01
Potosi Missouri
Agreed. I have considered a headache rack, so if I did that I want off-road lights installed for sure and that would be a great place for the switch. Same goes for a brushgaurd bumber with added lights.
mars2878
I agree, It looks like I should have options to do something with it for sure. I have actually been looking for some type of phone mount to fit in there but never found one. The switch idea is not a bad idea though.
Try the link that I provided above.
He has 3d printed plate parts to go on the right of the hvac controller. These pcs include the ability to put a phone mount.
mars2878
He has 3d printed plate parts to go on the right of the hvac controller. These pcs include the ability to put rocker switches or USB ports.
mars2878
That's where the traction control button is on mine.
Please provide the specifics of your truck. Are you willing to grab the part numbers off of it?
In 30yrs+ of stripping vehicles, I personally have only seen 1 truck with a Traction Control button & it was on a 99-02 model & the switch was directly to the left of the Passenger Airbag Switch.
99-02 Switches
Left IP Switches
- Traction Control - 15062589 - ACDelco #15062589
- Autotrac 4wd (NP8) - 15709327
- 4wd (NP1) – 19168767
- Power Fold Mirrors - 15062588
- Pocket - 15732033
Bottom
- Cargo Lamp - 15714159
- Fog Light - 15714113
- Cargo Lamp/Fog Light - 15752869 - ACDelco #D1552G
- Rear Wiper - 15714119
- Rear Wiper/Fog Light - 15735839 - ACDelco #D7062C
- Blank - 15735838
Right IP switches
Top* (housing is integrated with switch or plaque)
- Onstar - 12450568
- Rear Wheel Steering (quadrasteer) - 15177433
Bottom* (housing is integrated with switch)
- Onstar - 12450789
Left
- Aux Lamp / Emergency Vehicle Roof Lamp - 15722980
- Rear Object Alarm Disable - 15062424
- Electronic Suspension - 15052073
- PTO switch - 15040484
- Rear Fog (export) - 15715117 - ACDelco #D1570F
- Fog (export) - 15729517
Right
- Power Sliding Rear Window - 12463419
- Headlamp Leveling Activator (export) - 15036455
- Stabilitrack/Traction Control - 15062423
- Airbag Disable - 15036140
Other
- Blank Cover Single (pack of 5) – 15734687
- Blank Cover Double (covers both bottom openings) – 15075115
- 2 pod housing (blank top) – 15040483
- 3 pod housing (wide top pod) - 15074689
- 4 pod housing – 15207878
- Storage Compartment - 15756680
- Mat for Storage Compartment – 15024920
03-07c Switches
Left IP Switches
- Traction Control - 15764411
- Autotrac 4wd (NP8) - 15136039
- 4wd (NP1) - 15136040
- Pocket - 15732033
Bottom
- Cargo Lamp - 15143155
- Fog Light - 15143157
- Cargo Lamp/Fog Light - 15076588 - ACDelco #15076588
- Rear Wiper - 15143159 - ACDelco #D6316E
- Rear Wiper/Fog Light - 15143158 - ACDelco #D6378D
- Blank - 15735838
Right IP switches
- Onstar - 12450568
- "SS" plaque - 15178169
- "Intimidator SS" Plaque - 15783816
- "Hybrid" plaque - 15803575
- Onstar - 12450789
Left
- Aux Lamp / Emergency Vehicle Roof Lamp - 15061687
- Rear Object Alarm Disable - 15763185
- Electronic Suspension - 10363575
- Accessory Power Receptacle On Off (Hybrid) - 15776718
- PTO switch - 12497678
- Rear Fog (export) - 15061688 - ACDelco #D1582G
- Fog (export) - 15061686 - ACDelco #D7095C
Right
- Headlamp Leveling Activator (export) - 15763184
- Stabilitrack/Traction Control - 15061684
- Airbag Disable - 15270598
Other
remove cubby and you can fit more stuff in it
Find thing you want to stuff in it, then use something to keep it from falling in behind there, easy with flashiing or probably aa chunk of wood etc
What is everyone doing with this hole that doesn't have the automatic 4 wheel drive buttons?
mars2878
99-02 Switches
Left IP Switches
- Pocket - 15732033
Bottom
- Blank - 15735838
Right IP switches
- Onstar - 12450568
- Onstar - 12450789
Left
Right
Other
03-07c Switches
Left IP Switches
- Pocket - 15732033
Bottom
- Blank - 15735838
Right IP switches
- Onstar - 12450568
- Onstar - 12450789
Left
Right
Other
Lots of useful stuff, thank you.
Some of that, I've never seen, some I didn't know existed.
