Changed the Serpentine belt and pulleys.
__roger__
Texas
Worked on my truck (SUV) today, and I am happy about it. I'm not a mechanic, but over the years I have been slowly building up my skills and experience. Everything went well, but I do have a question about belt sizing, see below.
There has been a loud (intermittent) high pitched whining/growling noise coming from under the hood. At, first I thought it was my transmission since it has hard shifts and leaks fluid. I'm not a mechanic so I assumed it was the transmission since I know it has been acting up lately. The transmission fluid was low so I filled it, and afterward the noise seemed to go away, but then it came back not too long. A friend told me it could be the serpentine belt pulleys. So I got both serpentine kits from Rockauto (the upper that contains a tensioner pulley, and idler pulley with a bet, and the AC tensioner pulley and belt). From what I read the Gates brands was supposed to be a pretty solid choice.
I was surprised how easy it was to change the components. The old pulleys did seem to be worn. One of the pulleys spun fast and made a hollow sound, and the other pulleys did not want to spin at all. I started the vehicle up after the maintenance and the engine engine sounded smooth. I will drive it to work tomorrow morning and hopefully the noise doesn't come back.
One issue I ran into was that I could not get the upper belt installed. It was too tight. I slacked the tensioner pulley all the way and still could not get it to go. I ended up having to use the old belt, and luckily it still looked pretty new. I read that there are at least two different sized of alternators, so maybe I have the larger one? I looked at the alternator before I bought the kit, and thought I identified it properly. I'll take another look, unfortunately, I don't remember if I thought it was the larger one or smaller one.
Question: is the new belt that goes around the crank shaft and alternator super hard to install when new? I think if I somehow would have gotten the new belt on it would have been way too tight, but idk.
__roger__
Texas
Comparing the new belt vs the old might tell you if something is off. Otherwise checking to see if everything is set up correctly.
I noticed the old one was a little bit bigger. I wasn't sure how much a belt would stretch, but it actually did still look pretty new, so I'm guessing it wouldn't have stretched all that much.
Should be within 1/4" or 1/2" of the original.
I remember once my mechanic replaced the AC compressor on my old 4.3 and he couldn't get the belt back on. We figured the remanufactured compressor had a different pulley, since that was the only thing that had been replaced. He went back and got a longer belt from Napa and all went well.
The LS has a separate belt for the AC compressor, so that doesn't apply, just an example of how things can throw things off.
You either got a different size pulley or wrong belt. Put the old tensioner to figure it out...
Mikloangelo
Look up the RPO codes in the glove box and it will tell you what size alternator you have. They require different belt lengths depending which you have.
FYI, take a picture if the RPO codes and give it to AI to decipher. Much faster this way
105 amp:
Dayco
5060923
Poly Rib Belt
Specifications
Description:
Poly Rib Belt​
Compound:
EPDM, Aramid Reinforced​
Backside Material:
Rubber​
Rib Depth:
Standard​
Top Width:
.82​
Metric Part:
6PK2345​
Number of Ribs:
6​
Rib Profile:
Straight Rib​
Thickness:
.169​
Effective Length (in):
92.32​
145 amp:
Dayco
5060930
Poly Rib Belt
Specifications
Description:
Poly Rib Belt​
Compound:
Backside Material:
Rubber​
Rib Depth:
Standard​
Top Width:
.82​
Metric Part:
6PK2360​
Number of Ribs:
6​
Rib Profile:
Straight Rib​
Thickness:
.169​
93​
the first 2 are relevant, ignore the 160 amp one
U
__roger__
Texas
Thanks everyone. You have been a lot of help! I took a picture of my RPO codes and fed them to chatgpt:
Based on your RPO list, the key code here is:
  • KW1 – High-capacity generator (alternator)
For a 2006 Suburban 1500 with the L59 5.3L, KW1 typically corresponds to:
145-amp alternator (standard "high output" unit for SUVs with rear A/C, Bose, etc.)
I just confirmed my Rockauto order, and see that I actually orderd the 105 Amp belt. :confused:
At least I won't every forget what size alternator and belt I have.
Mikloangelo
Bummer you ordered the wrong one. But at least you know now, and rockauto may refund you if you are still within the window.
