Exhaust setups and clips
2003tahoe
Houston, Texas
well yall probably already know but for those that dont here it is
tecas speed long tubes going to 2 3" magnaflow high flow cats with a 2.5 y( just because the bend was to tight for 3" mandrel tubing) to a 3" piping to a 3" glasspack out to the bumper
some say loud but it sounds mild to me
Damn I want a cam change so bad
I have a Super 10 on my truck as well 3.5 I/O with all 3" pipe though, I'M getting ready to upgrade to a 4" magnaflow system soon. Should be sweet
As far as the cam change, Its not toooo bad, But have at least 1K saved before the start of the project or buy parts until ready to do swap......you never know what comes up.
I hate mine, I want to get rid of it soo bad, it sounds like dookie under medium throttle, it sounds nasty as hell tho on camera and in cab, but it doesn't have the " sound " I'm searching for, plus it " raps " alot
Yea, I had a set of tires like that before on one of my other builds, but a simple cam swap solved the noisy tires an gave way to noisy exhaust lope lol
bigcountry78
N.C.
I've always run flow master 40 series american thunder on my trucks. My 06 has single in dual out and I've gotten several compliments over the years. Tried glasspacks and straits on my 98 but I always come back to flows. If this one ever rusts out I may try a magnaflow, haven't decided yet. I don't have any sound clips but I'm sure y'all know what a 40 series sounds like on a 5.3.
squeaky3
Pontiac Il
I plan on doing the dynomax 4" single kit on my 6.0 or make my own similiar to the kit with a 4" muffler I have in the garage from my old lbz duramax.
not sure why you 6.0 people think you need sewer pipes on your truck, honestly unless your pushing like 600+ hp, 4 inch is just overboard, but i mean, if it sounds good, then more power to you
sounds good, my only complaint is it sometimes rattles on the crossmember
Try bending the hanger off the 3" pipe (in between the y pipe and muffler) down, it will lift the pipe away from the crossmember, if you want I can send a pic of what I had done to stop that
Sent from the Sierra Club
im supposed to be changing my header gasket this weekend so ill have the mid pipe disconnected, so ill give it a try and see if it helps
