Tire size, Lifted or Leveled
Erki
Alberta, Canada
Cranking stock keys all the way is all aftermaket lift keys will do, but they will allow more crank than stock. So yeah I'd try cranking stock keys first to see how much you can get. If you want more, then get leveling keys. I should have done that first. Probably could have gotten enough out of the stock keys. How much bolt do you have that you could crank? IIRC one turn on the bolt is .25" lift approx.
962000chevy
What I did was find a flat level surface then measured all four fenders to see how far off they were. Then I looked at my bolts and saw the passenger side had more threads exposed to I figured id max out my driver's side and measure it to see how far up I could take my passenger side and keep it level side to side. FYI my fenders are 38.25" inches up front and 39" drivers side rear and 40.25" passenger side rear.
sierra4.8
35s
Thoughts? 35" pro comps leveling kit and trimming
saw a guy on fb, that had 37s under his truck with nothing but a leveling kit and he said the rubbing wasnt that bad......
2003tahoe
Houston, Texas
Mine has a 4" suspension lift and 33" tires and they rub when a full turn going right on the wiper fluid cover thing
There is no way a guy is fitting 37's on a GMT800 with a leveling kit!
I second that, 33s and leveling on one of these trucks is pushing the limits, my friend has 285s and leveling kit on his 03 ECSB silverado and they start to rub a bit before full lock up
sierra4.8
I trimmed the plastic fender wells and yes I can turn full lock both ways
sierra4.8
Looks awesome...can you turn?
Quite a bit of trimming done but I could run these tires I put 75 miles on them but it would be virtually all on the road there's not much clearance for any flex but they looked good
The truck I mentioned above rubs at the back of the wheel well by his mid flaps and not at the bumper
Sent from the Sierra Club
I have 33x12.5 on 18" negative 3.5 inch offset rims with a 4.5" BDS suspension lift, never rubbed
Sent from Team Sierra
