cluster upgrades
everyone should know that for gmt400s you can get a esky cluster for your truck so you have a 120 mile an hour cluster, is there an option like that for a 2000 Z71?
Old77
I don't know what work is involved but you might be able to put a 01-06 esky cluster in
i just dont know if there is something kinda like the gmt400 where its a direct fit and its kinda common
Old77
Well I know I've seen the escalade cluster swapped in a lot on the gmt800 so I know it's doable. Maybe someone else will chime in with info about if it's plug n play or what work is involved
NathanJax
Jax, Fl
2000-2002 are compatible. 2003+ use completely different wiring.
Here's my 01 Tahoe with Esky cluster
Old77
eBay is your best bet unless there's a good salvage yard near you
i do have a couple of junk yards that ive found and re sold obs esky clusters but never have i seen a nbs, does the trans temp work?
NathanJax
Jax, Fl
trans temp work fines. All the wiring is there, just the cluster is needed... it's plug n play
