Chasing a fuel problem
Kkirwan71
Just replaced the fuel pump and regulator in my 2000 ecsb 5.3. Still have a stumble and a rough idle
Any ideas?
Kkirwan71
Plugs, wires, ignition coils
Cats could be plugging up
New plugs and wires about 3 months ago. Just gave the throttle body a good cleaning. Weird thing is if I do something it'll straighten up decently for a few days then do everything all over again. Also have a vibrating sound coming from it
Kkirwan71
No I'm not sure where the noise is coming from
Kkirwan71
It's not throwing any codes either
Kkirwan71
Update: vibration feels like it's coming from the regulator
Kkirwan71
Replaced the regulator (for the second time) still have the same noise
badazzbulldog
medway,ma
if you can get access to a scanner that reads live data like my soulus pro you can monitor misfires which I did on my 02 5.3 which led me to the injectors that were bad wasnt throwing codes either,also what brand plugs did you put in?
Kkirwan71
Acdelco rapid fire platinum. Whatever oem called for at the time. Is the solus pro expensive?
Kkirwan71
Oh dear god the solus pro is too much money for me haha
badazzbulldog
medway,ma
yeah its pricey I bought mine for $1200 off the snap on guy that goes to my friends shop software is up to 2010 us,asian and euro handy tool got it in june already made the money spent on it back thru jobs done with it.I run the 49-110 ac delcos uredium in both our 5.3's just did the envoy denali today had horrible idle and major skip did plugs its like a new truck
Kkirwan71
That's what they were the iridiums they're a little pricey
Kkirwan71
Replaced the mass airflow sensor today and still nothing. I've been told the ecms in these trucks have problems and need reflashing. I'm thinking black bear tune instead of a factory flash
badazzbulldog
medway,ma
have you tried unplugging one plug wire at a time to see what cylinder it might be. the one with no change will be where the issue is. could be a bad injector.also with an issue going on you'll want a reflash to factory not a tune that could make matters worse
Kkirwan71
Thank you for the input. And no I haven't tried any of that. My stumble isn't nearly as bad after the fuel pump but the idle is terrible. I messed with the plastic screw thing on the side of the throttle body as well because after I cleaned the throttle body I had a super high idle from it
