Console swap
Chbaird94
My 04 z71 has the bench seat up front with the flip down console. I want the full console with cup holders and such and meets the dash. How would I go about swapping on of these into my truck??
You'll need to grab the passenger side dash bezel or cut your existing one up to make the console fit, the rest should be remove and install after that
I would recommend you go to a local pick and pull and find a good console, remove it and see what differences your dash has from that one and figure out what needs to be removed from your truck to make room for the console
MYT HI
wisconsin
Bonecollector got it spot on. The only problem is the non console trucks do not have the provisions to make the vents work.
