peterjford
I have a 2006 Suburban with the 5.3L engine. I noticed that there is an Engine Oil Timer you can view via the buttons on the steering wheel. Currently it is at ~47%. Is that accurate, or should I go by mileage? It currently has 67k miles and was planning to change it at 70k. Once I change the oil will it reset by itself or do I have to do that with some magic combination of button presses?
My last question is the Dino vs. Synthetic oil question. I don't want to start a debate on which is better, but does the 5.3L like one more that the other?
I know that if you ask that question with Jeep owners you will likely start a flame war. All Jeeps either leak oil, or are about to start leaking oil. I use synthetic in my XJ (Cherokee) because I only drive it about 4k miles a year so I change it every 6 months. So far I have been able to keep ahead of the oil leaks. My wife's Rav4 doesn't leak oil, but it does seem to burn it (or it's hiding it somewhere). I have been told by other Toyota owners that the 2.4l engine does better with dino oil and it won't burn it as fast and synthetic I am about to switch back from synthetic to dino on it to see if it helps. I just want to know if there is any preference for the 5.3L engine.
Thanks in advance,
Peter J. Ford
Thanks in advance,
Peter J. Ford
