Need some help
Kkirwan71
I'm putting a headlight flasher in my truck. Where's the best place to get power from? And best switchable source to use? Also best place to run wire through the firewall for a switch?
The little battery box near the alternator for power, place a switch somewhere on the dash bezel like the flat spot behind the signal arm, you'll see near where the steering shaft comes through fire wall there's a few spots where wire bundles come through, sneak in by one of them
Kkirwan71
I still need a switchable source that cuts power when the keys off
Kkirwan71
Another question guys where's the easiest place to mount a switch
I will take a picture when I get home, it's a good spot, I have two switches mounted
Not very hard, just pop the dash bezel off and it'll be easy to get at the cover piece and stuff, if you wanted you can always drill into the same spot my extra switches are
