Removing drop bracket lift question
zachammer85
tucson, az
I've finally accumulated all the parts needed to return my drop bracket lifted 2500 suburban to stock height. My question is for the people that have also done this to similar trucks; what did you have to do to replace the driver's side differential frame mount? Mine was cut off to make room for the diff to be dropped. Does anyone make a piece to replace this or am i stuck having something fabricated or cutting a mount off anther truck frame to have it welded in? I'd rather not drive around with the diff only attached from the axles, top mount and passenger mounts.
DateNight
Tx
need to look at your front differential. I remember having to cut the mounting ear off and installing a bracket. It’s been awhile since I’ve lifted a ifs GM.
