Stripped Bell Housing-to-Case Bolt
KaulinGraves
River Valley Arkansas
Welp, I was able to get help with a table for my transmission. It’s finally off the pallet that I put it on probably 1-2 months ago. Great, awesome, outstanding ………. too outstanding. Went to take the bell housing off, all came out no problem, but one singular bolt stripped. I used Kroil penetrating fluid on all of them twice over and let it set a minute or two between. Others were mostly no problem, no stripping, nothing at all. Any tips on extraction bits or tricks? I don’t own a drill, dremmel tool, or welder. I could try to get the maintenance guy at my workplace to help me out, but I pissed him off when I put the table up to his specifications(he cut the wood and pre drilled holes, I just assembled it), and it wouldn’t go together. Turns out he drilled the holes wrong and told me that if I “couldn’t figure out a box, I shouldn’t be working on my transmission”. Idk about yall, but I took offense to it. Either way, I’d rather not try to weld a nut on if possible. Any help is needed, thanks
Umm, well that's gonna be a PIA to get out without any one of those tools...
I would try to hammer in something that fits as close to that. Heat it with a torch. Either a hand impact driver (I don't own one, but hear they work well) or an impact gun.
I'd drill it, using the head for centering. Then put an old school straight flute extractor in it.
tmpass
MA
I also believe these are not standard T-50 torx... they use a T-50 "torx plus" bit... too much play in the standard bit causes stripping.
too late now I know, but just an FYI for future
sux working on these things without any tools... I'd heat it to cherry red and hammer the next size bit in, then use slow steady torque on it rather than an impact.
KaulinGraves
I was using a torx plus bit. I ordered it from Sonnax. I’m thinking it was either the weird angle that it’s in the bell housing, or whoever was in the transmission last. Either way, I’ll probably replace all eight with the ICT Billet hex bolt style for easier access next time(hopefully I won’t need it).
KaulinGraves
Update on the stripped bolt:
Tried to use a blow torch the heat the area around the
bolt after drilling it out and tapping in a flute extration bit, didn’t drill it deep enough so I went to drill it again after it cooled off a bit. Drill bit broke off inside the hole and have no way to get it out. Having a friend of a friend meet me next weekend to weld a sacrificial nut on top to take it out. I’m starting to feel defeated on this
Hang in there Buddy.
I spent like 2 or 3 days trying to remove the transmission drain plu on my 99 Silverado when I did the engine/trans swap. In fact, that was probably the mist tedious job TBH.
Had to get my stick welder, 50' leads and welded a big 'ol 3/4" nut under the truck, overhead w/o burning the dead grass on the side of my yard, catching the truck itself on fire, or catching myself on fire! Fun times!
KaulinGraves
I could only use my buddy’s small torch on the inside of the bell housing as there was OLDDDD oil stains on the top mixed with grime and fresh Kroil. I told him there ain’t no way I’d do the outside of the trans lol
KaulinGraves
Update:
We have a success! Saturday when I posted the last update, me and my buddy used a dremmel to cut a gash in the head of the bolt and use a ground-down dovetail as a wide flathead screwdriver to get it out but couldn’t. Today, I was off work from a blown transformer on the side of the building so I got in contact with the same buddy’s friend that worked at the farmer’s co-op to help us and he used an air-chisel in that same gash. Took about 20 minutes of working it back and forth to get it out. You can tell the threads are trashed in the middle of the bolt. When we tried to drill it, the drill kept going to the side so we broke part of the side of it. But I think the threads are alright on the casing and hopefully the bell housing. I don’t see any damage. Might go in with like a thread-chaser to ensure. Thank god
