Stutaeng's 2006 Suburban 2500
IDK. SMH. I changed 2 unknowns, so I couldn't rule out one or the other...
Either the loose solenoid connector, or a bad starter. I haven't returned the starter for the AAP core, which is $40. I'm debating that...It "could" good and I can keep it as a spare if it was the connector? What would you recommend?
Maybe have them test it?
So, it was "handed back" by you and not a shop that looked at it?
I never took it to a shop...The first starter I replaced based on symptoms of non-crank. If it was a GMT800, I would have checked voltage at the purple wire, but since that really wasn't easily done, I ordered a starter replacement from RA.
I bought the rear jounce stops from "the jungle" of Amazon. I'd bought these same ones and installed them on my Silverado w/o issues last year.
Well, on the Suburban the studs were too short. The inside frame rail has a spacer or something. I went and bought longer bolts and was going to tack weld to the metal part, but decided to just cut a slot on the bolt head to prevent it from spinning.
I had to use a weedeater spark plug tool with a flathead so i could clear the axle tube. Job took way longer than anticipated.
I bought another front speed sensor (from AAP) because the GM Genuine didn't fix my issue. Recall that I reinstalled the little shim that the Timken had.
Yesterday I tested the GM Genuine with a DVOM, and no AC signal was being produced while spinning the wheel hub. I tested the AAP outside, and getting it close to the wheel studs, did produced some voltage.
So reinstalled the GM Genuine and removed the spacer and confirmed signal was being generated now. The faster I turned the wheel hub, the higher the voltage (still very small voltages albeit.)
But still same code. Doh!
I'll try my luck with the AAP sensor now I guess. If that doesn't fix the issue, I'll have order another replacement hub.
Umm. The ABS light went out today driving home. Earlier I also saw the service tpms briefly but that went out too.
Maybe it just needed longer driving?
Well, the ABS light is kicking my butt... light came back on. I went ahead and replaced the AAP Carquest replaced and nothing.
So I gave up and ordered a new Timken bearing from RA.
On another note, I finally filed a claim with RA and they shipped another Hydroboost UPS had lost in transit. I haven't seen any more leaks from my Hydroboost, but will replace it anyways.
I'm back on the minivan: today I decided to do an ATF fluid replacement. It's got around 97k and the owner's manual said something like 90k severe service, 110k normal service. The other day my wife said the money light came ON and I checked it and it's a transmission TCC code. Had already planned on the ATF fluid service.
I'm done for the night though...1. I stripped one of the pan bolts heads. 8mm pan bolts, seriously? almost as good as if they'd used drywall screws. 2. The oil filter broke at the neck. I had to chisel it out in pieces. 3. The magnet was loaded with grit. 4. I just stripped a pan bolt threads reinstalling the pan! I was using a 1/4 torque wrench, and some of the bolts had started clicking. I think some of threads had silicone, maybe that messed up the torqing?
Ok, this is another day :) and I could use some brainstorming and wisdom.
Should I try my luck refill the transmission? Or should I try fixing that stripped thread? I have a basic SAE/Metric tap and die set, and a mostly complete drill bit that goes to 64ths.
I'll probably head to the hardware store to see what bolts they have there. I believe this little mom and pop hardware store even has Helicoils, although I've never used those before...
@stutaeng, I personally would do the complete transmission service and filter change. No flush! Personally, when I do work here at home, I run a tap in holes on most of the holes I took a bolt out of, before reassembly, especially if I am gonna torque them.
I would at least try to tap the hole and see what happens. Or see if you can find a self tapping bolt that fits.
I went and bought a M8 tap and screws, but decided not to try drilling it out because I'm not sure if that's a through hole or blind hole at that location. And I didn't want to remove the pan again.
So I installed a 1/4-20 screw in there temporarily. Refilled and went for a drive and seems like it's shifting well and no leaks. The tcc code had showed pending and it came back on, but I didn't really think the fluid replacement would do anything for that.
Since I bought this truck, the headlights have always been ON. I have to manually turn them off when I fire it up. The little sensor on the dash was MIA and I suspected it had fallen down the dash. My aftermarket stereo screen is always dim because the truck thinks it's dark, which makes it hard to see in the summer sun.
Removing the dash seemed like a huge PIA, but I finally decided to do it...well, to my surprise, it's incredibly EASY! And my sensor is in fact, there and it WORKS! So I won't even need the replacement sensor I'd bought awhile back. No parts required fix!
I do have a small crack on the dash, so while it's out, I'm gonna try fixing that...might as well paint it to get rid of minor scratches and spray some Lizardskin...'cause my GMT800s "are" the 1977 Camero that I must have had in my previous life, but can't afford in this life! Lol1000008815.jpg1000008816.jpg1000008818.jpg
Last week I removed the bracket on the project Suburban because this one bracket had some rust. Vehicle was a former ranch truck and I accidentally left the hood open for some time and it rained.
So I just decided to repaint all 3 GMT800 brackets, as well and the curved brackets at the top near the hood/fender.
IDK why, but I find painting things relaxing, whether it's house paint, painting old machines, woodworking or furniture pieces, or in this case, boring old truck misc. parts, lol.
Also painting the 14 bolt 10.5" axle I plan to swap into the project Suburban...red calipers! [monkey covering eyes emoji]1000008785.jpg
I went the local O'Reillys looking for that dash glue to fix that crack. I was thinking that fiberglass mesh, but didn't buy it.
I found some 16 guage (?) plates in my garage I can't remember what I was gonna use for so I cut a piece to fit and glued it in as a reinforcement over the crack, next to the metal clip...well, I got to thinking that was a good idea, so next thing you know, I cut a bunch of metal pieces and glued them in across the front on each side of each metal clip.
I had to go buy more glue and they only had tan instead of black. You won't see any of this, so not being picky. Hindsight being 20/20: i think continous flat straps from clip to clip would have been a better idea, but couldn't really do that with the metal stock I had. Regardless, I think it's gonna be stronger now.
Definitely not too pretty! But good enough for the girls I go out with. :)
