Torsion Bar Ride Quality
25fabworks
Pa
Can my Tahoe use torsion bars STIFFER than 'XM'? Looks like XM were the stiffest GM OE torsion bars for GMT800 suvs, including PPVs / SSVs,
as well as 4WD Suburbans & Avalanches 1500.
If GMT800 1500 pickup trucks came with OE Z85 / Z60 handling package using WZ / YK / YT bars,
why can't I 'get away with' using at least WY / YH bars?
(Hummer H2 bars look like they'd be WAY too stiff for any Tahoe ...)
My 'phantasy' is a Tahoe that can 'intercept' GMT821 PPV, using parts loosely interpreted as 'GM OE':
6.0L, 4.10s, and a suspension built from OTHER GM OE parts where possible, especially for the suspension, I.E: a GMT921 PPV rear sway bar.
I wouldn't see why you couldn't use longer bars. Just see if you have the room to move the entire mount back. Checkout that torsion bar thread and you should have a good idea. You could also crank your current bars up a bit. They'll stiffen up if you twist them a bit. Just don't overdo it.
Hoping it won't be necessary to move the mount back ...
Don't think I know enough about 'twisting' torsion bars to stiffen them, to prefer this over choosing a stiffer torsion bar ...
JorgeS
Anderson, IN
You may already know this...
A longer bar is a softer bar
A larger (diameter) bar is a stiffer bar.
There is math that can give you compararive stiffness between bars as you vary the diameter and the length.
I say "comparative" because the final effect on ride dependsnon many factors.
