Posting this since I just used it to find the beacon light wiring above the headliner in my 06.
First remove the b-pillar trim, watched this vid to see how thats done
once thats done remove the rear grab handle and drop the headliner enough to reach in and pull the wiring out of the brackets attached to the roof structure.
I rolled up the wiring and left it at the bottom of the b-pillar behind the trim panel until I need it to power auxiliary lights or something.
Heres the electrical info - P A-24 is where the beacon switch info is.
https://www.gmupfitter.com/wp-content/uploads/2021/05/2006_LD_CKFullSizeElectrical.pdf
Cheers!
-j-rod
Cheers!
-j-rod
