Command start killing battery?
SK101
Sask
I have an aftermarket Fortin command start in my 04 silverado, every 2 weeks the battery is 100% dead when not using the truck (because i still havent tracked down the random misfire code problem)
Anyone with an after market command start tell me if this is normal?
I have one of these and have used it one time to help locate an intermittent draw. It was worth it.
BUT, I would never have a remote/command start, even if in a cold climate like you. Eventually they cause problems.
The amount of vehicles I have fixed by unplugging, or telling the owner to unplug, an aftermarket remote start! In Alaska everyone has one and unless it factory I can't stand them!
All you need to locate parasitic draw is a multimeter that does amps, a couple gator clip leads, and some pliers for pulling fuses.
The link I posted is for a meter that attached at the DTC/DLC connector and bypasses the battery and then you don't disconnect the battery to read the ma draw thru the negative battery post and negative cable end.
And it's neat. But $200 is also a little steep IMO for that. I'd rather not run an unknown level of current through the DLC either.
SK101
Sask
Slight update. It wasn't the command start.
After getting the truck running (i gave up and paid professionals) I parked it for the winter and removed the battery. A month ago i got it out of the shed - yes winters are long here - and removed the command starts wires completely, taped everything up, and it sat for 2 weeks awaiting brake parts.
It is now dead. Dead dead. no chimes, lights, dings, or clicks. It boosted just fine.
So tomorrow i am checking for parasitic draw. i see from here the IPC fuse is a likely candidate, any other prime candidates?
