Finally happened. Lifter tick. (Fixed)
Took the wife, kids, and dogs up to the Mogollon Rim this past weekend. Tahoe ran great as usual. 16mpg pulling our camping gear trailer up the big hills is pretty decent.
We were way out in the sticks and didn't see another human all weekend it was fantastic. We were able to let our dogs off leash the whole time and it was great. Stopped on the way home at a self serve dog wash place to get them clean before heading the last 5 miles home.
THREE MILES from home I lost a lifter. Could hear it clacking away. Sitting in the driveway at idle, it sounds awful. I'm hoping it didn't wipe the cam and I can get away with replacing the lifters.
Not good...Sorry to hear that.
My 04 project Suburban (that's been sitting for years now) also developed a tick and a misfire. I had parked it at my brother's house for several months. I drove it home and didn't go away. Got home and had a misfire on #7. Checked spark and wire and was okay. Did not have an even sounding compression sound when cranking so I removed the driver's side valve cover and rocker was very loose. I removed it and tried to remove the pushrod and it was bent. Doh!
No sure what happened? Got other projects going on, so will have to wait to find out the damage.
Hopefully it's just a lifter in your case...Keep up posted.
I've got no other symptoms than the tick. I'll start with the valve cover. Maybe a rocker is starting to let go. Not sure if that would be better or worse. But I'm not digging into it until Saturday anyway. It's my DD and I'm sad about it. But I've got my motorcycle and my wife has her DD and her motorcycle too. At least I can get around.
5202500HD
AZ
Just rolled past 225k.
Our 2015 GMC Yukon Denali XL just did this. The 6.2 only had 126,000 easy miles. Problem with just doing the cam/lifters is that if the lifter or cam got damaged, metal circulates throughout the engine. The cams have a laminate on them which degrades and leads to the issue. Sooner or later a bottom end knock will develop. I got quotes from 3 places for a Jasper with AFM delete and felt it wasn't worth it. Sold it for $10K with full disclosure last week. Luckily the 2500's and up don't have AFM especially mine with the 5spd manual. I'll never own another vehicle with AFM (Active Fuel Management) or DOD (Displacement on Demand) both GM garbage technology in my opinion.
Very smart decision.
My '06 is not a DOD engine. And with 225k on the clock, if it is just a collapsed lifter, it will get new lifters. I checked the oil for sparklies right after I shut it down and found none. We'll see when I open it up.
Didn't take the heads off. Going to be a while for parts to get here. But I did order lifters, rockers, head bolts, and gaskets. My buddy has a LQ9 cam if I need to replace the cam, so we should be good for parts.
Here's a rocker. She's a little bit loose. Click for video.
Lots of very worn lifters and rockers. I DID manage to catch the damage before it spread. All the lifter rollers were in good shape and the cam was good.
Managed to do the work without pulling the manifolds all the way out. Just pulled the manifold to head bolts and there was JUST enough space to wiggle the head bolts out and back in.
Back to being a good running truck. Actually runs better than it did before. I expect that the timing and valve lift is back in spec. I bet I was losing nearly 3/16" lift based on the play in the lifters and rockers.
Happy for you Tominus and the old girl. And very happy it wasn’t worse and you caught it when you did.
I’ve always been amazing at how vehicles will get you home and then die or present their issue as you approach home. It’s like they have it in them to get you there like a loyal dog
Especially when it is a GMT800.
Drove about 50 miles since putting it back together. Almost far enough to trust again.
As far as parts go, I used all Enginetech parts sourced from RockAuto. I was pleasantly surprised at the quality. I've never used their stuff before. I got Enginetech rockers, lifters, head bolts, and head gasket set. $460 for all of it. The gasket set was actually really nice and complete. The rockers are the upgraded design with the c-clip retainers and hardened pivots. Head bolts had sealer pre-applied to all of them. Lifters came in sealed trays, coated in mineral oil or something similar.
I also needed to replace all the spark plug wires. Several came apart when pulling them. Used mid-range Amazon ones for that. They fit fine. Autolite Double Platinum spark plugs. (Yes I know OE are double irridium, but GM has knocked it down to double platinum for non-DOD engines.) Snapped off the plastic end on the coolant temp sensor when I was reinstalling it. That was the only part I broke and needed to get locally.
750 miles since being back together. This weekend I finally cleaned up the last of my mess and physically checked every rocker and lifter. Out of 32 components, only one was still good. I would say it was definitely time.
Power has gone up, mileage is the same, and most importantly, she's smooooth.
When doing these, is it advisable to do the head gaskets and have the heads machined while you're at it?
I'm coming from the GMT400 world, but I figured it was similar with the LS based platform.
Umm, not really. Or it depends on conditions on your heads. Higher mileage heads could benefit from valve stem seals, if anything else.
When I did a DIY rebuild on my 06 Suburban LQ4 2 years ago (due to an intermittet lifter tick similar to OP's case), I had some refreshed 317 heads for another 6.0 I was slowly building, so I used those. The original heads were fine (even though they had 265k on them), but I still got them remachined/refreshed for the 6.0 I was slowly building. I would say that was optional for the remachining, but probably a good idea for the valve stem seals. You can replace the valve stem seals at home with a few basic specialized tools; no real need for machine shop. Just flip them over and add water and see if compressed air from the top of the valve causes air leaks.
I have a friend that has like an 03 Tahoe with the 4.8 and has over 400k on the original. He says it burns a bit of oil, but otherwise runs good. At that mileage, remachining is probably necessary.
Like stutaeng said, machining is usually not required. You HAVE to remove the heads when doing lifters, so head gaskets are a must. I have HEARD of people reusing MLS gaskets, but I've never seen it myself. To get that deep, you're going to need intake, exhaust, valve cover, and other miscellaneous gaskets anyway, so a head gasket set is cheap insurance.
My head gasket set came with valve stem seals, but if you look at the picture of my combustion chambers, you'll see it wasn't burning a lick of oil. No reason to do those. And if I do develop an oil consumption issue, I have the stuff to do valve stem seals while the head is still on the engine.
