Truck wants to start on the first ignition turn 5.3
Ignition switch in column. Very easy to get to and replace.
In the future, please supply all truck info. There are a lot of 5.3 engines in a lot of "trucks".
There is actually 2 stages before you crank the engine and are turning against the spring load. The second step would be accessory. The first step just unlocks the steering wheel. Are you saying the dash lights up and the engine cranks, when you move the key from the lock position?
@Lukas washburn, is each and every single 1999 thru 2006 truck with a 5.3 engine, the exact same thing? Since it is not, please supply truck info. Or is it a secret?
OR, are you a one and done and not posting anymore?
tmpass
MA
when i swapped the motor in my 07, not having all the grounds connected caused very odd cranks... truck wouldn't run without the headlights on, then it wouldn't shut off without turning off the lights... ignition key did not always operate correctly... dash and displays did not operate correctly headlights dim on passenger side, normal on drivers side
finally found one ground that i had missed was disconnected on the passenger side bell housing,
That was the only one i missed and it wreaked havoc.
