Loose steering
It's right there and a PITA to get to. If I am gonna cram in that far to do that bottom column bearing, the cross bolt it hangs on is right there. The push rod for m/cyl. Has to be disconnected to drop the brake pedal and the switch is right there. I have done the bushing on a 2005 Tahoe. Tight fit for my big frame. I removed seat and laid in there and did it. The column bearing is right there. Do it all then.
