GM Bearing Kit needed less than 2k miles after rear diff seal replaced
2500Life
PNW
I realize I'm asking for an opinion, but I thought I'd see if there was a consensus. I have a 2001 2500HD 4x4 with the 8.1-liter engine with 158,000 miles. Much of that mileage was towing our 30ft 5th wheel over the years as the gas mileage is too atrocious to use as a daily driver. My local shop has been working on the truck for 10 years and hasn't ever given me reason to question the service. Other than routine maintenance I've had very few issues with the truck.
My concern is that there was a failure of the pinion bearings less than 2,000 miles after my local shop replaced the pinion shaft seal and performed a full rear diff service. Included on their work order was "Inspect internals and reassemble with a new gasket." We were 500 miles from home when the rear diff failed, and I had forgotten about the prior rear diff service (it had been 5 months since the pinion shaft seal replacement - the truck doesn't do much towing in the winter and early spring). The rear differential shop that installed a GM 11.5 Bearing Kit noted on their repair order "Looks like someone replaced the pinion seal, overtightened preload on bearings. Rough pinion bearings and metal in housing."
Again, I had forgotten about the prior pinion seal replacement, so I didn't think much about the repair shop's comment on the repair order. I honestly assumed it was from work performed years ago before I began working with the current local mechanic.
When I got home and pulled the prior repair orders, I noticed the rear diff service that had been performed in November. I discussed my concerns with the local mechanic, that being was it reasonable that the rear diff failed less than 2,000 miles after the pinion seal replacement and service, and their response was that the failure was just coincidental and due to the mileage on the truck. They had a very descriptive and reasonable explanation of their procedure for replacing the pinion seal and that it was unlikely they did anything that contributed to the failure.
I'll never be able to prove the nexus of the failure. I'm just curious if others here think it is possible that the failure was coincidental (due to the mileage on the truck), or if the failure after less than 2,000 miles from the prior rear diff service was likely caused by faulty work when the pinion shaft seal was replaced. Good auto repair shops are difficult to find, and I'd hate to jump ship unless it was clear my local shop likely contributed to this problem. Obviously, my confidence has been shaken.
I've got a small pinion seal seepage on my 06 Suburban 2500 with the 9.5" SF axle. It doesn't drip oil, but it still bugs me.
Looking around, some folks say just mark the pinion yoke nut, undo everything and re tighten the nut to the mark. I'm skeptical of that procedure TBH.
My plan is to remove the carrier, measure the preload, remove the yoke, reinstall the new seal and tighten to get the same preload. It's a time consuming process, but it's the right process.
Otherwise, there's a high risk the pinion bearings will get damage in short order from preload being too high or too low.
So in your case, without knowing if they met the pinion preload specifications, it's hard to say one way or another. I think not enough preload will cause the bearing to chatter and failure of them will be galling. Too much preload will cause overheating and you'd have discoloration and blueing. Do you know what happened to your axle or what exactly failed?
BTW, welcome to the forum. We've got some guys here from the PNW.
Here's a description of pinion gear preload, what it is, and why it's important. Same applies to the differential carrier bearing preload: https://www.google.com/search?q=wha...CAA&sourceid=chrome&source=chrome.ob&ie=UTF-8
It's not uncommon when rebuilding an axle to overtighten the pinion nut (especially if using an impact gun) on the yoke and overcrushing the crush sleeve, resulting in too much preload. You have to remove the yoke, and install a new crush sleeve, which is a PIA and rebuild kits only comes with ONE crush sleeve. Obviously, you won't complete the job until a new one arrives in the mail and you can repeat the process.
Welcome to the forum!
Sorry about the failure. There's no way to KNOW why it failed. It could have been the other shop, but 2000 miles is a long way if it was their fault. Crush sleeves suck. I hated doing it on my 8.5". Next time I'm doing a crush sleeve eliminator. Then you can do services like a pinion seal or a gear swap without needing a crush sleeve or some other method of not replacing a part that supposed to be replaced every time.
