Start with your basics, like you are saying. Pull plugs and number them and post pics. When ALL plugs are out, do a compression test. Maybe even a cylinder leak down test if results warrant it. Do you have a bore scope? Look for leaks, too.
I would suggest a cheap Amazon catch can. https://www.amazon.com/EVIL-ENERGY-Universal-Reservoir-Aluminum/dp/B081N392BNSo before I start any of that. I think my problem might be the PCV valve, or lack of. When putting on the intake manifold fold and the new valve covers i didn't think to put one on. I connected straight from the valve cover nipple to the intake manifold. Reading up on it, it seems to fit my issues. Will report back once I've installed an inline PCV.
Are you sure on the resistance value?Okay, I had time rip my dash apart (again) to mess with my ambient light sensor issue. I found a few things.
1. The ambient light sensor plug was plugged into the glove box light and the glove box light was plugged into the sensor. Swapped those around. The light sensor has a grey and white wire with the Grey reading 5vdc. The glove box connector has an orange and black with orange reading 12vdc.
2. The light sensor is bad. The system should see over 4vdc when exposed to light on the white wire, which is your signal to the bcm. I was only showing 2.8vdc, which appearently isnt high enough to take of "night" mode.
3. When jumping the gray wire to the white wire, I should see the auto mode kick off because the bcm should be seeing 5vdc on the white wire, but it doesnt do that.
4. Wires from sensor to BCM have continuity and are not shorted to ground. This tells me the BCM has an issue. I can buy one off ebay, flashed to my vin for $179.
Ordered a new sensor, and will test that first before I decide to buy a BCM.
There is a nipple on the valve cover on the passenger side. Well, head? Idk. Anyway it goes to that side valve cover inside. That is the necessary vent if your orifice is over-produced vapor wise, so the intake will still allow increased pressure somewhere to go(the lower vacuum side of the throttle where iac would have once been. )So before I start any of that. I think my problem might be the PCV valve, or lack of. When putting on the intake manifold fold and the new valve covers i didn't think to put one on. I connected straight from the valve cover nipple to the intake manifold. Reading up on it, it seems to fit my issues. Will report back once I've installed an inline PCV.
Not 100% certain. I will say when I reconnected the bcm after reading for resistance of the wiring, the headlights stayed off in auto, then after 5-10 seconds they came on. So it was able to see the sensor but never would "unlatch" when it received the 5vdc on the white signal wire. I tried to recreate the anomaly but its wouldn't do it again. Im getting a new sensor today, and will disconnect the battery before trying again before i point to the BCM officially.Tha
I have after market valve covers which doesnt include an orifice for the PVC. The new ones have nipples only. I had to connect the inline pcv from the drivers side to my intake manifold. Actually it goes from valve cover to PCV to catch can to manifold. The passenger side i have hooked up to my air intake behind the MAF sensor.There is a nipple on the valve cover on the passenger side. Well, head? Idk. Anyway it goes to that side valve cover inside. That is the necessary vent if your orifice is over-produced vapor wise, so the intake will still allow increased pressure somewhere to go(the lower vacuum side of the throttle where iac would have once been. )
Then the pcv on the other cover is an orifice. The rattle kind can’t be used because it’s part of the cover
Like the Sony! What model number did you pick?I also decided to swap out my cheap temu radio with a Sony 7 inch unit.
