i recommend using blue loctite or just high temp sealant anyway for the bolts. although not likely to end up like the water pump bolts on a Small block ford, its good idea to keep the threads from corroding in there so you dont end up needing a super high torque value or end up with a ruined fastener etc.Removed and replaced the old water pump. Definitely was leaking thru that weep hole.
I didn't see on my maintenance log where the belt and tensioner have been replaced (but I did replace the AC belt and tensioner previously), so I'll order new ones later. Tomorrow I'll stop by and buy some Dexcool to replace.
It took me about 45 minutes to do the job. I didn't know this, but i had installed sealant on the water pump bolts on this truck when I swapped the engine. You don't have to do that because, unlike the previous generation engines, on the LS the water pump bolts are blind holes. All you need is the gaskets (no sealant on those either as I was doing before.)
I spent about 10 minutes cleaning the old thermostat sealant on the water pump bolts. SMH
Thanks!Great looking truck, I love the gold.
My squarebody was gold and white, and my wife called it goldie. I think paint has to be really bad redone before it looks it, because the factory didn't do concourse paint.Thanks!
Was planning on repainting it because I'm having clearcoat failure. Until the last few weeks, I wasn't concerned about the color, but recently read that gold metallic is the MOST difficult to paint of all colors.
I repainted a door on my 06 suburban, which is a silver color. Turned out okay, but was using a 1.7mm gun. Apparently, silvers are a also very challenging to get right a and color match. Aside from the bad clearcoat texture, I can't tell the color difference on the door. So at least that gives me some confidence. Not sure if that's real confidence or perceived. Lol
Thank you, Sir!"my wife casually said our 2013 T&C minivan was overheating the other day."
Overheated once or numerous? Kept driving when did overheated? If only once and you overheated as well, that ain't good. Compression test and post results. Pics of the plugs in cylinder order. Make sure to have all plugs out before the compression test and a battery charger on the battery during the test. You want the same cranking rhythm through the whole test. You can get a chemical test kit at the parts store to check for hydrocarbons in the coolant. A good top bottom, side to side and front to back inspection. Pressure test cooling system. Be really great if you had a bore scope.
Post all pics and test results here.
Plus, that bad oil cooler typically leaks oil and not coolant.
