2000 Silverado z71 refurb
bigdogYJ
Kommifornia
Yeah the guy I use here locally is really good. He’s been able to align anything I bring him perfectly. No that’s not my rack. That’s the alignment shop.
I do have a buddy where I do a lot of my automotive work with both a 2 post and 4 post drive on lift in a 6k sqft shop. I’ve been very blessed to use that pretty much at my disposal. It’s just a 3hr drive away so takes a little planning. If it’s not drivable then gotta plan to tow. Not a huge deal. It’s a pretty easy drive to be honest, as long as I avoid commute traffic getting out of here.
My shop owner friend has a 2 post and plans for another. Not enough room for a 4 post. I can use the 2 post if absolutely need to but only if wide open. He stays very busy there.
bigdogYJ
Kommifornia
Well I ordered replacement tail lights and headlights/marker housings. Headlights and markers look ok. But the tail lights are missing the black trim around the housings like the originals? When installed they look like crap. They don’t line up well at all. Anyone have any luck finding decent quality replacements with the black trim?
I typically use TYC and so I looked for you. The TYC and DEPO look like what you show in the pic. The Dorman design does show a darker area where they divide but they are not raised like the OE ones. I even checked CariD and they just have the dark etching, like Dorman, but nothing that is raised like the OE ones.
bigdogYJ
Kommifornia
Interesting. If I remember correctly my 2006 Silverado dually had the same design tail lights is this one with the raised black trim. These housings aren’t terrible I think I was looking for an easy way out to get some clean looking housings. I’ll just plan to put in some elbow grease and cleaning these up as best I can with the cerakote kit.
Thanks for looking and confirming what I saw.
Like you, I like the look of the new light assemblies. Makes the truck look cleaner. I like to stick to a complete stock look but it may take some looking for replacements that have that raised black rib.
I did find these two choices at ebay though:
bigdogYJ
Kommifornia
Yeah those look like the same dark area like the dormans.
I did find these…
2003 Chevrolet Silverado 3500 - Driver and Passenger Side Halogen Tail Light, Without bulb(s), Fleetside, OE comparable
I actually just noticed that my own 2005 Tahoe Z71 had the raised black stripes. The ones listed at RA show that the complete assembly looks the same size but the location of the different lenses are stacked differently.
bigdogYJ
Kommifornia
Yeah that’s interesting. These are definitely original. I’m the original owner of the truck and know for sure they were never swapped.
I found an old pic of my dually and it had the same design. I’m not the original owner of that truck but I will say the black trim ring finishes it off nicely.
Nice job on refinishing those. They look great. I’ll see if I can remove the black trim. That would make it easier to clean up and refinish then put it back on.
bigdogYJ
Kommifornia
So maybe it was a z71 thing? Doesn’t explain my dually though. Yeah the suv and pickup invert the brake/tail with the turn signal I believe and they are a bit wider in shape compared to the taller shape of the pickups.
bigdogYJ
Kommifornia
Actually the brake/tail move to the bottom and the turn and reverse move up. And no reflector. Interesting how different they are. At first glance all GMT 800 look the same until they switched the pickups to the all red housing. Interesting the dually never got those red ones. My buddies 06 I’m pretty sure had the same design as mine with the black trim.
Yea, my Tahoe Z71 looks like these.
bigdogYJ
Kommifornia
I was successful in getting the front seat covers installed. Not sure I’m a fan of the center console condom thing. But we’ll see. So far I like that the seat covers don’t move when getting in and out of the truck .
Next gotta work on the rear seat. Then steam clean the seat belts.
How much were the seat covers and how much of a PITA were they to install?
I just checked and RC does not make seat covers for my truck.
bigdogYJ
Kommifornia
~$200 they are listed as 99-06 Silverado ext cab.
the fronts weren't terrible. There's 2 nylon straps with buckles that run front to back under the seat. Then there's 2 elastic straps on each side with a plastic hook that I believe are supposed to run under the side and hook to each of those nylon straps but the clearance to get those under the side is kinda tight. I haven't done that yet. but it hasn't needed it yet. if I wasn't planning to pull the seats out in a few months to give the carpet a deep clean then id probably unbolt the two nuts from under the front of the bottom seat cushion and lift up the lower cushion/cover/etc and connect the elastic that way.
I've heard the rears can be done with the seat in place but it's far easier to remove the rear ext cab bench so you can get behind the rear seatback. I'll report back how that goes in the next few days.
