If you do replace the harness, with a quality replacement, like you should and is recommended by oh so many people, you will not have to CHECK IT, except for anything that could have damaged the old harness.Started getting P0332 (comes back after reset), so ordered all the parts to replace the knock sensors. I'll also check the condition of the wiring while I'm under there.
What do you mean by the grommetSo it was a slightly different failure mode than I anticipated. The rear knock sensor valley was filling slowly with coolant once I disassembled. So had to do some parts runs for more gaskets during the job.
I also installed the updated valve cover that's supposed to have better baffling for the PCV. It didn't have a grommet for the PCV on the VC, so just adapted an OEM one with some adapters I had laying around.
No photo of the terrible RTV dam I did based on the GM TSB.
well it can, you just only make sure its not blocked, but with no rattling/spring valve in it , its just a in-out make sure its clean and clear. so less involvedI don't really trust one that can't be serviced.
I'm sticking with my solution. I appreciate the concern though.well it can, you just only make sure its not blocked, but with no rattling/spring valve in it , its just a in-out make sure its clean and clear. so less involved
id still like to know the answers to my questions if you can, im not trying to control your actions id like just to know what is what and helping ensure you dont have 2 pcv in a row etc
can i at least have clarifications on what exactly you did? a the questions i asked were becuase im not sure how youre piece you created fits in the picture of , maybe some final install pics and just describing what all is doneI'm sticking with my solution. I appreciate the concern though.
yes his last sentence he said he didnt include a photo of his RTV "dam" per the TSBDid you use sealer on the knock sensor harness rubber plug in boots? The last pic posted shows the harnesses plugged in and is nice and clean but I see no sealer.
That's what I get for only reading before the pics.yes his last sentence he said he didnt include a photo of his RTV "dam" per the TSB
Remember you need a new beltView attachment 4936
Just wrapped up doing about 2k miles of towing for the latest race. The bearing inside the 105A alternator is starting to make a serious groan, so ordered the ACDelco Gold #88864277 replacement that's listed as 130A. Figured that would give a little more buffer if I move to electric radiator fans.
$129.99 + $35 core fee.
Nice truck and cool thread! I see you're using the "beefy" Dorman RD stuff. I'm not typically a fan of Dorman, but the marketing got me. And, I gotta say, I've been impressed. The Dorman stuff has lasted at least as long as the Moog stuff I took out.View attachment 3626
Installed new endlinks, UCA and LCA ball joints. The original ones were very stuck. It was tempting to just replace the entire control arm.
I usually heat the arm (or component, whatever you're working on) evenly with medium heat until the bushing starts to smoke. Then I briefly aim the heat at both ends of the rubber bushing to really get them burning. I little 'pop' from a screwdriver and the bushing falls out.When they "burn" them out, they are just melting the rubber bushing and then the inner sleeve falls out and the outer sleeve is easier to "coax" to fold inward to make it easier to remove....or press out.
Yes, the right rear also is for the left front. The right front is also for the left rear. 2 part numbers cover all 4 corners. I have them on my 2005 Tahoe.I'm not sponsored by Dorman, but maybe I should be. The right rear exhaust manifold bolt had long broken off in the head prior to my ownership. It's a common problem due to thermal cycling, mixed expansion rates of these three materials and the crappy GM fasteners.
Installed this bracket to solve the minor leak without pulling the heads to extract the bolt. Dorman 917-142
is the passenger side exhaust manifold supposed to be split in 2 pieces in the center?Yes, the right rear also is for the left front. The right front is also for the left rear. 2 part numbers cover all 4 corners. I have them on my 2005 Tahoe.
