New to Me GMT800? (Edit: Our New Yukon)
Rear brakes done! This truck will be new soon. Might even get to the rust issue and fix that.View attachment 4285View attachment 4286View attachment 4287
I dont see any lube on the brake pads or the clips , so not complete.
I also dont see any cleaned up hub from the rust shown before, or any anti seize evidence under and above the hat (only need a tiny bit to keep the wheel mounting surface from getting rust jacked, and the amount under the hub to keep that from rust jacking at all)
zachammer85
tucson, az
Here's the heater core tees Dorman makes. I couldn't remove my old ones, so I just broke them off with plyers. They definitely get brittle with age.
I decided to remove the quick connect integrated to the hose that comes from the large tee that hooks up to the reservoir. O'Reilly's only had red hose, so that's what I had to use. Whatever.
On my Silverado I have the hoses hooked up directly to the aluminum tubing, but the SUVs have rear heat, so you can't do that. Hopefully these metal ones last a long time...
Currently attempting this on my 01 suburban. The quick connects seem impossible to remove not to mention it's difficult to get a tool in there too release them. Any recommendations? I have both the dorman metal tee fittings you have there as well. Tia
Try some long needle nose pliers. I don't remember specifically what pliers I used, but I have a long pliers of something like this: https://www.amazon.com/Amazon-Basic...-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
Start chipping away at the little nipples, then go after the main connectors. The plastic should be brittle. Once you start, it will be a lot faster and the whole connector will fall apart.
On the second photo I posted, this is the Lisle quick connect removal tool. I honestly can't recall that I used it, more like I think I was going to use it, but didn't need to? Can't remember now, LOL. But here's the link for that: https://www.amazon.com/Lisle-39190-...19539b796db21e5f126ad1e&qid=1765309487&sr=8-6
zachammer85
tucson, az
So it sounds like the best option is to just destroy the old t fitting and keep the heater core and aux pipes in tact and replace with the new t fittings?
Absolutely correct. Either replace with GM/ACD or those metal ones out there. If you try to salvage them, the heater core tubes can get flumuxed.
